A9 mkII + Essence mkII : incompatible with Chromecast & Deezer Hifi
I hope someone can double check, bu it's a complex use case :
I cannot send music from the deezer app on iOS (iPad +iPhones) via chromecast to my B&O stuff (mkII Essence and mkII A9, so not last gen) with a deezer hifi subscription.
What I can do is send deezer hifi to a chromecast audio (that's why I think the issue is B&O related), and send spotify or any other app audio to my B&O stuff via chromecast.
I can also play deezer hifi directly to the B&O stuff from the B&O app, but that means that I cannot access the personnalized playlists such as deezer flow. I can also Airplay, but that means lower quality and battery drain on my iStuff.
Can anyone try if it's just my setup or if it's global?
Bonjour Marc
Deezer app 8.29.0.4 on iOS 14.3 (iPad 6th gen) : Deezer hifi to M3 (soft. 1.9.41630167401182) via Chromecast works effortlessly for me.
Wifi : 11n
Works here too .... but I had to insist a lot before getting it to work.
I could start Bandcamp Chromecast session against the same B&O speaker without any issue.
Could be related to Deezer + B&O Products CC setup?
Edit: I could not make it work with my M3, worked hardly with my BS1, I’ll test with more devices tomorrow to look for a common pattern
There is something with deezer, CC and B&O as I cannot get sound from my Google home mini ("play XXX in the kitchen" for instance) when the selected source is deezer. No issue with Spotify.
en effet ....
I have tried again from the IOS App to start a Deezer CC session against my B&O products, no luck. From the same smartphone, against the same B&O products, I successfully started MixCloud or SoundCloud CC sessions with , on top of Bandcamp tested yesterday.
I tried Deezer with Chrome on my Mac and I was able to CC Deezer against my B&O products without any issue.
I then noticed that Deezer IOS App could get the "control" of the flow that was started by Chrome/Deezer, i.e starting Deezer on the IOS App, selecting CC pulled down the session started by Chrome/Deezer, but here it stops, I was not able to pause the flow from the IOS App, nor to stop the casting.
I stopped the casting from Chrome, closed Chrome, and I was then able to use my IOS device, Deezer and CC flawlessly .... but after a couple of hour of inactivity, same problem occured.
I also noticed that when I start a Deezer CC session from the IOS device, I have a failing message, but the music seems to go on anyway (progress bar moving), while there is no sound and Google home shows no activity on the speaker.
There is definitively an issue with Deezer App, CC and B&O as you wrote. I'll raise a case with B&O and Deezer, and we will see if it is the start of a ping pong match ....
Still working this morning on my side 😮
I modified my previous message to include versions
Same version here.
To make the case more complicated, what failed this morning, works this afternoon ..... I have opened cases with both Deezer and B&O, we will see if they "bottent en touche"
My A9 Mk2 and BS2 work with CC fine, in my use case anyway.
My Roon Nucleus (server) can see all Aiplay and CC devices, and it sees both products.
I can use the Roon app (iOS or OSX) to trigger CC music streams on both the A9 and BS2.
Maybe not that helpful, but Roon, CC and B&O speakers (the ones I have) work fine.
Is your use case including Deezer?
Another finding:
Where I cannot start a Deezer CC flow against individual B&O products, I'm able to do it if I group them in a speaker group .....
