A8 subsitutes needed - Help!
Well, i've had enough of Bang & Olufsen A8's.
But, before you all recoil in horror, there's a reason...
Not every time i go running - but i'd say about once a month, the sweat gathers in the foams and ends up ruining one or other of the drivers.  Either that - or if it rains, the rain water does the same thing.  I remove them and dab the water off gently with my running top as i go, or remove the sponges and leave the A8's to dry on a warm radiator when i get home - but alas, the damage is done and another pair of A8's get relegated to the 'to be fixed' drawer.
So, I'm now looking at in-ear earphones as the way forward - and the Shure SE535 seems to be the best.  However, the Sennheiser IE8 is half the price and has rave reviews...  There are a plethora of these type of earphones around and to be fair my head is spinning!
Some "BeoWorld Advice" is needed here. Help!
Lee
Save on earphones and just sing really loudly as you run. It will have the additional benefit of warning others you're coming through.
Agreed. Just hum a little ditty.
Better yet, stop running altogether.
My recommendation would be these:
They provide extremely good isolation from street sounds, and while running, they act as a towel.
They provide extremely good isolation from steet sounds, and while running, they act as a towel.
Seriously though, others appear to get on with link. A bit cheap and cheerful probably but lets face it - you don't look your best when running -
Well, thanks for that expert advice Gentlemen - the Shure SE535's it is then.
Lee
Try these: http://www.koss.com/koss/kossweb.nsf/p?openform&pc^eb^PLUG i've heard they are not at all as bad as the price would suggest.
-Olli
I use the Shures myself Lee, they have been superb and no problems in the 18 months I have had them..
Jonnie
How much worse could you look!!😕👍
You can, with Form 1s, even worse with U70s. I've tried. :)
