Hi guys!
I have an A6 that keeps crashing. It happens when i use the B&O app (which is always)
In the settings utility, under critical it says "DSP Error Level: Service Error"
The only thing that fixes it is ud i unplug the A6 from Mains. At first it happened once in a while nyt now it is virtually unusable.
Of course i have testet stuff and found out:
Reset does not help
Chromecast works until the DSP crashes.
If i reset it and play something and i join the music in any other room the other Rooms are silent but the app shows that they are joined.
If i play something in another room and joins the A6 the result is that the A6 is silent.
Earlier i reset the A6 i could use everything for a bit with the A6 as main room and then the A6 crashed and the whole house went silent.
If i use any other speaker as main the whole house works as expected except the A6.
I have had the A6 since april i think. The only thing new in this setup is an M3.
I have contacted the support and the wanted med to reset, tried that. And then reconnect all bluetooth devices which leads me to the conclusion that they have no idea what is wrong.
My thoughts were earlier that it could be the B&O app using the DSP for volume control. But if i play music on A6 and manually joins other rooms by button, not the app, the result are the same.
Any inputs?
