A3 switching
Can anyone help me with this question, when switching the A3 into standby does this also do the same with the iPad 3 if not how can you turn it off without removing it from the A3 which does not make sense?
After I turn off the A3, the iPad 3 shuts off based on the Auto-Lock time I set in the iPad settings.  Are you saying the A3 turn offs an iPad 1 or 2 from the switch and the 3 doesn't?
Hi Symmes thanks for getting back so quickly, your advice has worked the IPad is new and l should have read the instructions because l did not know what the Auto-Lock time did but l do now thanks again.
Glenn
