A product idea for BANG & OLUFSEN
I know some people working at BANG & OLUFSEN are reading this forum.
I throw out an idea.
When will we see a WiFi phono preamplifier like the ARCH model from DEVIALET ?
I want to plug in my old devices to take advantage of them. Thank you.
Forget my last post. I read it again, and see this is a preamplifier for a record player:)
and that product is welcome :)
Not all (B&O) turntables need a preamp.
And for that price you could easily get a Beoplay M3 and a RIIA preamp (for the line-in connection there), which would give you the same……and more, if you use it in a Beolink setup.
Not sure what exactly you want to accomplish but I use this with my turntable and B&O Speakers and it works super great.
link
If that suits you well, it is a good solution.
However, what I want (and also do) is to make my Beogram visible/reachable/manageable/joinable from my other B&O devices e.g. my Beovisions.
And I think that this is what was behind the suggestion in the original posting/the suggestion to make a ‘B&O-version’ of the Devialet device.
