A peek into the future of NL ...
Removed the "camouflage" of a NL/ML converter and found 2 RCA and 2 more RJ45 sockets.
Good Lord man!  Are you trying to get us all killed?  😎
"The BeoLink Converter will have the Power Link sockets enabled, which means you can connect e.g. a pair of loudspeakers in a link room to the BeoLink Converter, install an IR eye and get sound distribution to this room from any audio or video source in the system."
Greetings MM
So the NL/ML converter includes a Beolink active.
/Räuber
Hallo Räber,
abwarten, Tee trinken - du wirst Wunder erleben.
Aber frag doch mal deinen Händler 😐
Gruss MM
Hi Millemissen,
I assume meanwhile dealers can ask US such questions!
/Räuber
P.S.: Please give us back your avatar!
There you go - puss is back.
Greetings MM
@Räuber Surely they could learn from us - or they could do their homework 😡
Grrr! MM
P.S. As for the NL-converter as a BeoLinkActice: You might say so....
I missed something.  Who is "they", what could they "learn from us", and what "homework" should they do?
Millemissen wrote:
... BeoLink Converter will have the Power Link sockets enabled ...
😁 ... it's important to stress "WILL HAVE" ...
