Bech312 wrote:
Hi.
I have the opportunity to make a good deal on a pair of Beolab 3’s.
It’s for my kitchen and today I just have a Beoplay S3 (playing via Bluetooth) ok sound, connects easily. Does the job well
Will the Beolab 3 play as fine as the Beoplay S3, even that the Beolab 3 doesn’t will be paired with a sub. Thinking of using a playmaker and play via an iPad
It is mostly because of the design I’m thinking about a change ( I can use my Beoplay s3 in another room) but I don’t want to, if the music quality will be worse. I think a sub is too expensive to add to this project
let me hear your thoughts - hope somebody can help me
I’d say - get the BL3’s, they are excellent speakers especially considering the size.
Only if you plan to play laud and the room is rather big, you will need the sub.....but that is a rather general rule with smaller speakers.
A Playmaker will be fine (mine is fine), if you mainly use AirPlay. Best run it with a wired network connection.
But do think of the other possibilities mentioned from Michael - they will give you more possibilities.
And do keep your S3’s they are good speakers in their way.I have one, which I like - although it is not used that much, I don’t plan to get rid of it.
Only testing at your own place - before you change everything - can tell you, what is best for you.
But having both setups should be fine 🙂
Please do tell us how you get along, once you have decided.
