It works !!!!
It works !!!!
Well, Almost…
The TV control part works flawlessly. Some commands are sometime a little slow to react, like "Mute".
But i suspect it's maybe an operator issue: I need to learn the the "quick touch" move. Otherwise, the remote send a volume up or down command.
All the usual commands are here and the less usual too. There is nothing so far i could do with the original remote I can't do with the Beo4:
- Classic TV commands (channels, direct and incremental, volume and mute),
- Menu, settings, adjustments, audio controls…
- Zapping back and forth between two channels,
- Media player, TV Guide, Channel list…
But,
The Apple Command part is not working at all. When i press the SAT button, the TV switch indeed to the HDMI port where the Mac is connected and I can see the remote is sending controls, But nothing happened on the Mac side.
I wrote to one remote asking if I may have did something wrong and wait for their answer.
So, to be continued still!…
A OneRemote Adventure.................in slow motion ;-)
It's not slow motion, it's realtime (which is quite slow, i agree!)
Speed improved - nice ;-)
Have fun with it.
Good evening to you guys,
I've send an email to OneRemote about my issue which is "everything works but the Apple controls"
They haven't answered yet, so i sent another email this morning.
When i was talking with them before buying they usually answered their mail in the following couple of hours, so I'm a little confused.
I will give them time…
Who said "slow motion" ? 😁
Well, Almost…
But,
Did you make the required programming steps....as described in the guide?
As far as i understand the user manual and the email talks i had with OneRemote, there's no need for any additional module. The RMB4 should control a non B&O TV AND the Apple device (Mac or Apple TV).
I remember purchasing Apple remote and solder it into a beo 4. Wasn’t great. Module RMB4 I think sold it with a tv. Did you get this?
RMB4 Module?
Surely hope they updated it.
Yes I did, Disabling and enabling again the Apple controls. Didn't change anything.
I'm sorry but if they're still no answer from OneRemote this afternoon, I'll open a Paypal case.
Hi
Mine is working just fine. Did you remember to activate Apple controls?
It’s done by pressing light menu stop 4 1 OFF That Will enable Apple controls :-)
/Allan
