As discussed in a few other threads, I have a BS Core which is great but for its lack of native support for high-rez streaming services such as TIDAL or Qubuz. The best I can do is stream TIDAL Masters (i.e., MQA) to my Core using Apple Airplay, which maxes out at lossless redbook CD quality of 44.1/16.
This bothers me.
I have high quality speakers and I want to be able to play the highest quality streaming source music on them so I did much research and looked to the Bluesound Node 2i, which has native support for TIDAL at 192/24.
After a day of listening, these are my thoughts, subject to revision as I spend more time with the device:
1. Connecting the Node 2i to my BL17's via Toslink doesn't seem to be a great idea. The Node 2i does not have a button within the BluOS app to tell the device to sleep/stand by. Thus, when the music stops, the player will after a few minutes of inactivity put itself to sleep. Unfortunately, this sleep setting does not appear to play nice with my BL17s (or other external DACs, according to posts on the Bluesound support forum). When the Node 2i goes to sleep, the sleep signal is either not sent over Toslink or not readable by the BL17s. The speakers remain powered on. This is irritating and a waste of energy.
2. Tone controls for adjusting treble and bass are also not active on the Toslink output. Bummer. I like a bit more bass.
3. Swapping the Toslink for RCA L/R connections to the BL17s fixes (1) and (2) above. After one or two minutes of inactivity, the player goes to sleep and the speakers turn off. Also, I can increase the bass pleasingly. Very good but annoying that I feel I must buy expensive and thick RCA cables that won't bend around the curves of the BL17 easily.
That said... I got the player working and sounding as it should. Thus...
4. THE BIG QUESTION... Can I hear the difference between MQA and CD quality TIDAL songs? After going back and forth on two songs I know well for probably 45 minutes... the answer appears to be no, I'm sad and a bit embarrassed to say.
I was hoping listening to TIDAL MQA through my BL17s (which max out at 96/24, unlike the BL50 and BL90 which can accept full 192/24) would be a revelation compared to listening to the CD-quality version of the same song.
Honestly, I don't think I could tell the difference if I did a blind A/B test. It's POSSIBLE the higher-rez versions sounded a bit more nuanced but if I have to try that hard to hear any discernible difference, then clearly it's just not worth it to my ears.
Have any of you had similar experiences? Or very dissimilar experiences?
I bought the Node 2i because I was upset that because B&O does not natively support TIDAL within its software, I am forced to stream CD-quality music to the Core. I wanted better than CD quality high-rez! That's one reason we have such amazingly capable speakers, is it not?
I wanted to try a device that allows me to A/B test TIDAL MQA at 96/24 (given the BL17's limitations of 96/24, not 192/24) versus TIDAL redbook CD at 44.1/16. Poor support for the Toslink output aside, the Node 2i is a capable and very, very easy to use device. Sadly, my ears do not appear to be good enough to tell a difference between lossless CD and higher-rez.
(I am ignoring any upscaling or upsampling, whatever the term is, the BL17s do on their own. Perhaps the BL17s are so good at "upsampling" music, they're doing me a favor by bringing CD quality sound closer to higher-rez sound?)
5. Which device to keep? I think the integration of the Core into the B&O app is nice, even if the software is a big buggy at times.
On the other hand, the Bluesound Node 2i will play the higher quality music; maybe for peace of mind that I'm getting the absolute best out of my speakers, I keep the Node 2i? Even if it requires I purchase new cables?
I will say, the BluOS app is extremely easy to use and setup of the Node 2i could not have been simpler. If I had regular, passive speakers, I would use this thing in a heartbeat to feed them and I would recommend the product to anyone who asked.
What if B&O spontaneously adds native support for TIDAL into its app? That's best case scenario. B&O, are you listening? We love you but how can you not natively support the two most popular high-rez streaming services thereby forcing us to stream at CD-quality??
Anyway, I will do some more listening and pondering and perhaps you all will have insightful things to say that will help me determine which device to use going forward.
I recall in another thread, a fellow forum member has a pair of BL50s driven by a Core and is wondering whether to try a Node 2i. To him I would say: Try it but use RCA cables. See if you can hear a difference.
Cheers and thanks for listening!
