70s nostalgia ?
Again, a speakers-question: these days some real 70s nostalgia shows up; it makes me think about the sound of the speakers  from that period, B&O produced some very good hifi speakers in these years (I own a pair of s45-2), how do they compare to the speakers of the 80s and 90s, beolab 8000 vs M100/M120? In other words, is there any progression in soundquality, I always thought the introduction of "active speakers" was more for the benefit of design than it was for sound?
I don't know if I can be 100% acurate as I mostly got experience with Beovox M150 and Beovox S45-2.
The Beovox S45-2 sound pretty good for their size. No lack of bass or mid/treble freq for instance. Sound is big enough for the smaller systems.
The Beovox M150 wich I use on a daily basis sounds big and clear in all details of the music. Again it was designed with that in mind.
For the sound of today both pairs does not sound dated really. I have heard a 5 minute demonstration of the Beolab 5 speakers and in honesty I was not impressed with the sound being better.
What about the amps too? For example: Is the amp in the Beolab 150 any better or worse than my BM 8000 connected to some Beovox Pentas?
I am glad you asked that question!
I can see that If I upgraded my BeoCenter 7000 and s45-2 combination I would get a more modern and compact system, that would have better connectivity (a real pain woth the BC7000) , be fully linkable, give me more control options and look more modern. That said, I have often wondered how much better it would sound, and reading therough a lot of the posts here It doesn't seem as is if improved SQ alone would justify the expense, but I am willing to be persuaded otherwise.
Simon
I'd love to be able to hear a comparrison between the two - I prefer in lots of ways the design of the 70's/80's equipment such as the old beosystem 8000 and M series speakers and did at one point think of changing to that series. The only practical problem I could see would be integrating it with the more modern stuff for surround sound and beolink etc.
 My neighbour has a Beocentre 7007 and MS45-2 (I think) speakers - the sound is very comparable to my BS3000 and BL4000 speakers. Another friend has a Beomaster 5000 fed only with an iPod as it's source and connected to Beovox Pentas - the sound on that is completely different and much fuller with more detail and much stronger bass.
I've heard it said before that the sweetest B&O amps were those built before the active speakers came about, so the BM 4000/4400/6000/8000/5000 are better than a BC9300 for example. To be fair though, if you wanted 150w from a BC9300. you'd just go out and buy some Beolab Pentas, so it's probably an unfair comparison to make really. You'd be a bit daft expecting to get real grunt from some Beovox Pentas using the power amp of a BC9300, in much the same way as it would be daft if you hooked up some Beolab Pentas to a BM8000, negating the power amp in the 8000...which kind of brings me back to the question of what is better amp-wise between Beolab 150 and BM8000?
I don't see how the design would benefit from making the speaker active since you need more room in the speaker.
(Some of) the old speakers, however, in my experience are very good. I have had a number of different models including Beovox 2702, 1802, P30, CX100 and S55.
Of the above I definitely favor the S55's which are used with a Beosystem 8000 in my parents' summerhouse. Unlike many others on the forum I didn't enjoy the sound of the CX's as I found it muffled and badly separated.
I prefer the sound of my BL5000's, though, over all of the above speakers 🙂
When it comes to amplifiers, B&O's amplifier from the 70's are state of the art soundwise.
The problem with them today is aging components, especially capacitors of course.
A well serviced Beomaster 2000,2200,...,6000,8000 will cover
the entire audible frequency range plus a little more the exact same
way a new Beocenter will.
Basically, there's only so much for an amplifier to do.
Linearity is good with the 70's amps, not really lacking anything
but there can be a difference in dynamic response.
I would prefer the 70s DC-coupled and discretely built amplifiers
to modern day AC-coupled and often japanese hybrid IC amplifiers any day.
The 70's amps lack of output (series) capacitors alone has a
great influence on the sound reproduction.
Output impedance is low = the amp has better "grip" of the speaker and damping factors are considerably better.
Wattage is not a great issue as a matter of fact - actually only when you like to play at party levels.
A Beomaster 2000 is rated at 40 Watts but given the right speakers it will sound a lot more, the larger speaker the better.
A Beocenter 9000 is rated at 30 Watts but will have a hard time driving larger speakers and you can hear it. It loses its breath so to speak.
Active loudspeakers are built to make sure that the amp and the speaker
are well matched. It may be a good idea but not always.
You can easily find better speakers for a Beolab 150 than the
Penta tower.
Besides, the Beolab 150 is not very different from what you will find in f.e. a Beomaster 8000 and the Penta speaker tower is hard to drive,
very inefficient.
Try using a couple of speakers from the JAMO POWER range of the mid-80's.
The 500 or 555 springs to mind with an efficiency of 0.8 W/96dB/1m,
yes 0.8 Watts is all it takes for normal "livingroom" level.
Connect to a Beomaster 8000 and you will see what it really can do,
you will be surprised, I can tell you that !
My BM8000 drives 2 pairs of the above with ease, that's 4 12" woofers, 4 midrange horns and no less than 20 dome-tweeters.
It's all down to the speakers efficiency.
Given the right speakers, a Beomaster 901 will sound a million.
Thank's Martin
After I posted my first response I got thinking that we are talking about 30 years old hifi here and the leason here is:
If the amplifier/speakers is fully functional and sounding right then it compares to todays B&O very well. I'm getting alot of Beosystem 6000/8000 research/service done at the moment and few B&O units of that age early '80s still work great/100% right. That goes for speakers too.
Some Beomasters do sound better with other speakers. I will agree with that.
Still its worth the money in the long run though if you know how to get it repaired right.
One way to compare would be to go to your dealer and listen to the newer systems.
I generally think you get much better sound improvements by changing your furniture or carpet that making speaker changes.  That's why for most people you're better just picking a good brand (to guarentee a fairly good standard) and then just choosing what looks best.  That's why I choose B&O over Bose and the 1980s stuff over other periods.  Given a differente taste in decor, it would be 70s
