5V power for USB feed on beomaster5500?
hi out there
I have added a chromecast audio as "tape"- and want this to be turned/powered when I turn on the 5500 -ideally would be when I activate "tape" but I can live with that it turns on when I turn on the 5500
It is powered by a USB cabel
Where would you suggest that I pull out the power for this on the 5500?
br /tiwabng
tiwang wrote:
hi out there
br /tiwabng
Very interestjng. I am following.
A master slave portable socket outlet might be another approach....
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Hmm please tryk to Explain this a bit more in detail - I intended just to pullout 5v somewhere from the 5500 which could supply enough power when turned on but if a more flexible solution could be implemented?
I agree with Kallasr - a "strømspare-stikdåse" would do the trick. The 5500 would be master and the chromecast would be slave and turn on when the 5500 starts using power.
Why do you want it to turn on and off? It is a device that is supposed to be in at all times.
What I do is that I have a audio feed going to the chromecast at all times, and simply turn my audio master on and off.
