Hello All
Does anyone know if its possible to control a beovision 10 through the usb or ethernet port? I'm looking for a method of interfacing with my home automation system without having to buy a masterlink gateway!
Warren
Hello All
Warren
don't think there is much chance for interfacing other way than through the masterlink.
Another solution could be an Irtrans box that come in both USB and ethernet and now also a wifi version. this box sends commands to the tv via an IR eye. There is a specific B&O version (455 khz).
http://www.irtrans.de/en/
No It's not possible thru USB/LAN only thru ML or IR
What want you to do?
Maybe Lintronic interface can help Link: Lintronic.dk
/Tompa
Thanks Tompa
I'd like to be able to send command to the beovision 10 as if I was using the remote but via rs232/ethernet etc (e.g power on, source select, volume)
I've had a quick look at lintronics and doesn't look as if its possible to control that way round as the bv10 doesn't have an external IR input connector
