3D files for BS9000
Hi
Does anybody has 3D files for BS9000 (DWG or...)
I am not sure I understand, what you ask about.
And I am not sure they used CAD sw, when the BS9000 was designed?
Depending on how detailed you want the model to be, you may fins something here:
Thanks matador43. This kind of files !
Only 2D, but EPS files can be found here: https://beointegration.com/3d-models-drawings-and-dimensions/
Thank you Kiwi for that link,
In fact, DWG and OBJ files are actually very well detailed 3D objects!
That's amazing!
