Yes, strange but true - that's the upcoming campaign Bang & Olufsen UK are launching with their dealers. I heard it yesterday!
They are offering a minimum of £500 for any Bang & Olufsen CRT Television as long as it's working and has a fully functional remote, and the only TV that it doesn't apply to is the BV8-26" (i can only assume there's no profit in them?)
One thing to note is that it's a minimum - so there may even be some "over-allowances" available if your TV is worth more and you push hard enough! In fairness though, now is the last time your old 80's BeoVision will be worth anything!
Although the press campaign doesn't start for another 10 days, i am told your dealer will honour the deal with immediate effect if you ask him nicely. Also remember that it's a minimum of £500, so if you have something like an Avant DVD they may be able to offer more than normal to clinch that deal - try them!
You heard it here first!
