Update APP of the B&O 7.0.0.
Good afternoon!
The application has been updated to version 7.0.0. and I will not find a very convenient function that was implemented in previous versions through the "Support" section - this is a wheel that shows the quality level of the connection over a Wi-Fi network and the SSID of the connection network.
With this function, it was possible to adjust the position and location of the Wi-Fi repeaters in order to achieve a better connection and its stability. It may have been moved to another section, as I was always puzzled by its location in the "Support" section when it should have been in the "Settings" section. However, I could not find this feature in the 7.0.0 update.
If anyone knows its location, please let me know.
Additionally, I noticed that the Beovision Contour image has disappeared, and I am unable to select either the view or the color. Instead, I am presented with an image similar to the Stage image. This is quite strange, as the Beovision 11 and 14 images remain in their respective locations. I wonder what the problem is.
V7.0.0 also removed: 1. Ability to play an entire folder of songs via UPnP DNLA. 2. Ability to close the Music Browser from any view.  Now one must back out all the way to the root view to close the music library browser. 3. Adding a song to the Play Que no longer closes the Add Song dialog -nor is there any audio or visual confirmation that the selection was added to the Play Que. It also was necessary to re-add my Home Media server to all IOS devices after the v7.0.0 “update”. The app still appears to have no means of clearing the Play Que other than one song at a time. Not sure why there is so little effort made regarding DNLA integration. Happy to hear of any solutions found for any of the above Joe M in WV
In the updated 7.0.0 app, the Bevision Contour image has been replaced with Stage for everyone?
Just FYI 7.01 is already being tested and fixes a lot of other problems.  Hopefully it addresses these issues as well.
My Tablet, Android 13, has been updated to 7.0.0 whilst my phone which is Android 14 is stated to be no longer compatible. Strange. Paul
So, no possibility to start a whole album.....
No, way to add something to a que.......
Also, the update does not work on my Mac, you only get some nice B&O imagery: J.
