Test Editing
Lets see if I can correctly edit this
This is a reply which I shall post and then look for the edit option. This is text typed after I selected the edit option. Works fine.
Beofan for many years with a penchant for 1990s audio systems.
<h4>test for profile</h4>
I noticed that you used a HTML tag <h4> Currently users cannot use HTML code in their posts, but I plan to add some code to allow a subset of all the common HTML tags. I will try and find time to do that in the next couple of days.. Keith..
