Stage / contour problem
Hi, in the current App i miss the settings for upmix etc. i saw these settings in older versions of the app. It was in the back screen and i have to slide from button to top https://support.bang-olufsen.com/hc/en-us/articles/360042563431-Can-I-change-the-listening-modes-of-my-Beosound-Stage can anybody help me? greetings
I do not have a Stage - however: There have been some changes in the app with short and longpressing of some of the buttons. Have you tried, if there is a change when you long press the menu? MM
hi, thank you for the reply which menu do you mean? Also i heard from long and shortpressing. But i do not know where i should do this. also i can’t find an explanation for this on the bo website. greetings
Best stay tuned for a reply from an actual Stage/Contour user - there must be someone here! My reply was just a hint, that might help - as stated I can not test it on a Stage. With the Theatre it looks like this, when I press the menu button for Sound Modes shortly. When I long press a more advanced menu for the actual Sound Mode appears. N.B. This is from the beta version - I do not know, if this also is in the regular version. Sadly you find little to no explanation for this behaviour on the B&O site…..I found out per accident. MM
I have Stage and confirm it's missing from 5.9 or 6.0 app version on iOS. I use testflight and dowgraded to 5.8.1 which is ok. I have no idea if they have any QA department, but to me seems like paying premium price and always run on beta app. Pathetic.
Thank you. I wrote to support. No answer. greetings
Hi, bo support wrote to me. Since 5.9 the UI has changed. the developer is informed. In Future updates the function should be return greetings
I don’t have a Stage, but it seems it’s fixed in the current app release (6.0.1)
I can’t see any changes. Can you make an Screenshot?
Stage>Sound Modes>Create New
