Speaker configuration
Hi
I have some beolab 9 on the back of my system and some 20 at front there driven by a eclipse
the speaker are daisy chained together my question is
When I change audio profiles even though the profile is set up to turn the back speakers off they stay turned on ?
But no sound comes out when the chosen profile is in use.
Should the back speakers stay on even though there is no need or sound coming out ?and the set up says they are turned off /
I use 18s as front and 4000 as rear speakers, the latter are daisy chained. They turn off if I change the profile e. g. from surround to stereo. My Eclipse is a 1st gen.
You say Beolab 9000 as rears, so you mean BL 9?
Kind regards,
Rolf
