Replacement Terminal Block Connector Recommendation
I am looking for recommendations for a replacement terminal block connector (minimum 7 wire pairs) for MasterLink wiring (yellow, green, brown, grey, pink, white, shield). The plastic in the original connector has become brittle which is causing some wires to easily pull out of the terminal block (see photo). Thank you!
They are very much standard:
https://www.biltema.dk/byggeri/elinstallationer/monteringsdetaljer/kronmufferakke-2-stk-2000017379
Here in Denmark they are available at most hardware stores / building centers.
That said the loose connection is not because of the brittle plastic. The screws are sitting in a metal piece which the cable ends are pushed into. It could be that the cable ends are not pushed long enough in, or that the terminal block is not big enough for three cables at the same time
