Products not updating?
It seems there's a new 6.5 release for some of the older products. Is anyone else having issues upgrading?  After about 4 tries, my BS1 (2nd Gen) upgraded, but my M3, Eclipse (gen1) either give me a failure message or complete, but don't update the software.  Trying to figure out if it's a problem with my network or with B&O somewhere.
I have a 6.57689 version on all my ASE products - but that is from back in October. They are on automatic updating. Most are hardwired, some on wifi. I am not aware that there should be any later SW. By the way….they all run flawless. A tip…when they won’t update - please restart pulling the mains. Then wait until they are online again. MM
You can view the latest SW updates here:
It turns out if I first go into "troubleshooting" and select the software re-start - a little easier than unplugging -  it will now upgrade successfully.  As timing goes, I have 2 Essences and a BS2 that upgraded in October, but didn't get the upgrade indication on the Eclipse, M3 and BS1 until recently.  Might be a US, thing. All works great now. Thanks for the comments.
