PowerLink - Pin out for 5V trigger
I have a playmaker and I've got the cat to powerlink female adaptor cable, which I use to connect to a Quad Power Amp - what I want to do is use the 5V trigger on the powerlink cable to trigger a relay to power up the Quad Amp rather than having to manually switch it on and off - does anyone know which pins provide that - I'm having trouble to find it on any technical details.
I mean the pins on the Powerlink Din cable
Powerlink Pin 4. I am posting for the second time because the first disappeared, possibly because I inserted a link.
Powerlink pin 4 is the one you need. I often refer to PeterPan's diagrams to check - scroll through the thread until you find what you need:
Great, thanks Guy - got what I needed - I've bookmarked it - it's excellent - thanks again
