Non B&O TV with B&O
I am looking to buy and pair a non-B&O TV (possibly an LG) with Beolab 18/19 speakers, controlled by a BeoOne remote. The Stage is beautiful, but cannot connect to other speakers, so that’s a no go. I don’t like the design nor price tag of the Theatre, so that’s also a definite no go. Is there any other way of simply connecting the LG TV with the speakers and remote? I read that the latest LG TVs have or will have native support for BeoOne - is that true?
Hi,   I think this topic will be helpful: https://forum.beoworld.org/forums/topic/control-lg-tv-with-beoremote-one/ I have not read about the native support, that could change things. I have a LG G3 which still needs a hardwired connection between the tv and an Stage or Theatre to use BR1.
The Beoconnect Core will do what I believe you want..... HDMI to BC-Core. Powerlink out to your Beolabs? You need to check with your Dealer but I think you will be able to load the Beo/LG App in the LG and get control??
I dont think the new Core allows the BR1 usage / integration that you get with a Stage/Theatre + LG. Also, the new Core can only connect a pair of BL's, i.e not a sub in addition.
You can still daisy-chain a BL2.  There is just no dedicated sub out.
