Neo Radio: Bluetooth, Internet radio solution from Denmark for B&O
I've just found "Neo Radio" box from NEOMESTEREN in Denmark: https://neomesteren.dk/en/produkter/neoradio It'll give our B&O systems some modern functionality: - Bluetooth - Internetradio - Phono Input - ... Looks pretty interesting and it even allows control via Beo 4 and Beoremote One. Seems to have a hard wired FM-Transmitter built in which enables you to feed Internetradio directly to the FM antenna input of your Beosound, Beosystem, Beocenter etc. Unfortunately I couldn't find any specifications about supported Bluetooth codecs. Does anybody have experiences with this?
Hmm interesting. Although I don't want to have to use a separate app to control my devices. I have a BS9000 and all I did was get a used Essence and hooked that up to it with all the features I need like multiroom, airplay, bluetooth, Spotify and B&O radio. No issues at all.
I know this product. (Btw - it has already been presented on the Beoworld Forum some years ago). It is developed and is sold as a solution for all those, who wants to maintain their MasterLink setup and - because they have lost the old school analog FM radio - wants to add an internet radio option. I find it very well described on the website. Also you can se the BT version (=4.2) there. I would not be worried about BT….nothing that I use, but it should be sufficient for those, who likes BT streaming. Also there is an option for including a turntable to the mix. Since the Aux input of the AudioMaster is used for connecting the box, this is via connecting this to the box. In my opinion a clever solution…. ……which unfortunately comes a bit too late for those of us, who already have migrated to a NL-based solution. MM
