N.Radio and NetRadio
Hi,   anyone else having problems getting the BBC Radio channels on both N.Radio (mine on a Beosound 5) and NetRadio (on a Beosystem 4)? I’m using this in Spain, it was fine yesterday, but both have connection errors now. it’s working fine in the UK for me though I wonder if the BBC have switched off their non-BBC Sounds support - although B&O assured me that it wasn’t going to be an issue!
I just checked N.RADIO on Beoport and the BBC stations will no longer play (they were working a few weeks ago), so it looks like this could be a result of the end of their 'Shoutcast' service which was due to be switched of mid-2023. EDIT:  You have probably seen that I added a post about this on an older thread for completeness, but as you have also mentioned NetRadio it is worth keeping this new thread too!
Strangely though, it’s working OK for me in the uk… at least NetRadio.
I'm in the UK and I've now lost all my BBC Radio stations (not sure exactly when they stopped; working when last used on 14 June but been away for a couple of days) on N Radio via a Beosound 5. I have been getting a message broadcast by the BBC over the last few months saying they are making changes to their streams and they would stop working mid 2023. I had assumed as the BBC is a major UK broadcaster that B&O would automatically switch to the new stream, looks like I was a bit naive. Now searching for a solution!
The problem is not B&O, it’s the BBC wanting to lock everyone into their (paid) subscription services.  A lot of stations are moving away from vTune, TuneIn etc… I think this is why B&O Radio was rolled out in the BeoApp…..it sorta gets around some of the short term licensing issues but stations are limited and often territorial. An embedded VPN on your Router (if supported) my give you limited workaround in some cases??
Well it has happened; they were warned; they said it wouldn’t be a problem; then it is… here is the response from B&O ——- Thank you for your patience thus far. We received an update from our relative department and we will do our best to assist you. Upon reviewing your case, we kindly ask you to take a look at this link as we believe that the issue you are experiencing is most likely related to this change that BBC made. We are currently investigating what we can do and will let you know when there are further updates. Should you require further assistance in the meantime, please do not hesitate to contact us again.
Yes. As per my last post. BBC are withdrawing free services. I am reading the same thing on Auralic board, same issue but less contact with Naim board and hear its happening through two to three layers of separation. BBC want you to have a TV Licence (if in the UK) and subscribe to either iPlayer or BBC Sound. The BBC are a totally out-of-date organisation and need shutting down, re-inventing and go to full commercial viability rather than rely on blunt extorsion (under pain of penalty or imprisonment if in the UK) of the licence fee. This is not a B&O fault by any measure.
Not really related to N.RADIO or Net Radio (as the thread title) I today thought I'd check whether my OneRemote (International Receiver Company) radio can still receive BBC internet radio. I bought this when I lived overseas to access BBC radio, hence haven't used it recently because here in UK I can listen to BBC on FM. Anyway, here's the outcome: So clearly the answer is 'no'.  I confirmed this by logging into the Frontier Nuvola Smart Radio interface, which controls the stations that I listen to on both this and my kitchen radio (a Hama IR110).  As you can see, the interface knows that one of my devices is incompatible with the listed BBC stations, although the Hama kitchen radio still plays them without problem. (click to enlarge) Luckily (for when UK FM is switched off) my OneRemote radio has the option to play DAB, albeit the quality is lower compared to the previously available BBC internet stream.  I just tested and it works well with full (direct or indirect) Beo4 control. So yes this BBC stream re-shuffle is causing a few headaches (more than just N.RADIO and NetRadio) but nothing insurmountable so far!
