Masterlink: Choosing an Audio Master
I'm helping to extend an existing MasterLink configuration. Currently, it connects only BeoVision TVs (BV7 and BV6). Audio is to be added. The problem is selecting an Audio Master. Devices to be connected include:
  • BeoCenter 2 mk 2
  • BeoSound 3200
  • BeoMedia 1
  • PC2
Logically, either the BC2 or the BS3200 should be the Audio Master. As far as I can see:
  • To access music already stored on the BS3200, the BS3200 needs to be the Audio Master.
  • To access the DAB radio on the BC2, the BC2 needs to be the Audio Master.
Obviously, there can be only one Audio Master! So the questions are:
  • Have I understood the limitations correctly?
  • Are there any other limitations I've not spotted?
  • Are there any other reasons to select one Audio Master in preference to the other?
Thank you (in advance) for your help. Mark
Also depending on software versions most of the products should be able to work as link room products (option 5 or 6) and be able to get the source from the Audiomaster with a Link + Source command.
I'm not sure whether I understand you correctly here. I'm familiar with the idea that a link room TV can access the sources attached to the video master. With later link room TVs, it was unnecessary to press LINK before the required source, as long as the link room TV didn't have that source itself. However the LINK prefix command simply meant "get this next thing from the video master, not a local device". Are you suggesting that if (say) the BC2 is the audio master, there may be a way to access the BS3200 via the BC2 over MasterLink, by using the LINK command? Or did you simply mean that commands can be routed to the audio master by using the LINK prefix (which is what I'm used to)? Mark
First of all sorry for taking some time to come back to you
OK, thank you for the clarification - it's very helpful. Now I can plan out what we need to do. Mark
Just thinking about the diagram that you referenced... The two ML networks are connected through back-to-back BLCs. How does one access the other? Is it (for example, from Core) N.RADIO gets network radio, whilst LINK, N.RADIO gets the phono from the second ML network? Mark
Ah! That makes a lot of sense. It does imply that I need to get the B&O technician to set up the NL/ML converter, though, so it'll be important to plan out future upgrades to get those included, too. It was the use of BLC in the diagram that made me think it was talking about the 1611 BLC, rather than the NL/ML converter (you used the correct term, but the diagram didn't - hence my confusion). Thank you for all your help. Mark
