LC2 Repair
Thanks Die Bogener. I initially suspected those IR board caps (C7 and 8, both 22uF) after reading this old thread:
I just got hold of a non-working LC2.  I have tested it with a old fashioned 60W bulb and  it's not responding to touch or IR. Internally, I checked the 5V supply in a number of locations and it's reading about 0.5V. I removed the main PCB from the casing and noticed scorch marks - you can see them just above the coil mounting in the picture below: I first thought that the scorching had come from the mains supply terminals but there is no sign on the terminals or around the other side of the casing. I therefore checked the PCB and found that Resistor 1 (bottom right, next to the Zener diode) has failed open circuit.  (I checked it in-situ because one terminal is not connected to anything other than the non-connected N terminals).  According to the manual it's 5.6 ohm, 10%, 0.4W. My plan is to simply replace the resistor and see if that cures the fault. Clearly I am hoping that this is the fault and not a symptom! Any comments/observations?  Anyone seen this fault before?
One observation yes: I've spent hours starring at non-working LC2's guts in the hope something like you've noticed will jump into me and I'll be able to repair them. After thinking it twice, I thought that even if repaired, it would be a nonsense to have to use any 40w bulb nowadays and dropped the idea. As fun and exiting it is to use B&O light control it do not worth it to me. (But I still have and use my little 6 channels magical box that Beodrives intertechno switches !)        ;)
Looks like a flame-proof type. Find the reason it burned and replace with one. Martin
I have repaired dozens of them. It's always the same. Caps defect. Especially the SMD ones on the ir unit are the worst ever... Check the capacity of them very, very exactly. There is a " .. , .." I replaced them with X7R SMD caps ... no electrolyth any more...
??? Yes it's getting to be a pain!  So much of my stuff is in boxes since moving to a rental in Feb.  We just need UK house prices to crash (any day now ...) and then I'll be able to buy somewhere permanent to live!!
There are 2 brown caps, the 220uf is prone to fail... yes, with shorts killing the resistor.
