How to wire 7 din plug to Beogram
Hi, I have just bought a 1970s Beogram 2000 with the 7 pin din plug cut off! can anyone help me with how to wire and connect a new plug to it please? there are 6 coloured wires, I have no idea which wire goes to which pin on a new 7 din plug? thank you all
Apologies, I meant 1980s beigram 2000
I suggest you look at Beotech
Can anyone help me with this? I have no idea which colour wire goes to which pin on a new 7 din plug. all I think I k ow is that the yellow wire is for data link…   thanks again
If you go to the BeoWorld main website and look at the top right you will see a link to Beotech. There are loads of wiring diagrams on there that may assist. Stoobie
Exeter, Devon, UK
Thank you for that, I’ll have a look. My brain doesn’t work in this way with these things ?‍? but I’ll see if i can work this out. cheers
Couldn’t find this in there. I can’t find a colour wiring diagram for pin on a 7 din plug for Beogram 2000. ill keep looking. If anyone has ever replaced the 7 din plug I’d be so very grateful if you could let me know the colour wire sequence.  Thank you
My brain doesn't work that way either :) Hopefully someone can assist Stoobie
Exeter, Devon, UK
Thanks for that Keith. I appreciate it. the yellow wire in that image of the 7 pin plug is going to #1 pin. I thought it should be #7 pin… The photos are helpful but I can’t see which pins the coloured wires are connecting to. Also the silver wire I can only assume is the ground wire, which I thought was the main black one (there are 2 black wires, one thinner than all the rest. im so confused, starting to wish I’d never bought this, but I did t k owned but the din plug off…   thank you though
