Hall Audio - closed
Sad news - the small danish company HALL AUDIO has closed. They made and sold the excellent (third party) Wifi Streamer with an HDMI input and had also an ongoing collaboration with Polypv for some interesting ML-products. I have no idea why they closed and what will become of the collaboration. MM
On the Beotalk Discord server PolyVection has mentioned that they are still working on some kind of ML streamer product, but have not had a collaboration with Hall Audio since the the unsuccesfull kickstarter for the ML streamer.
How was it different from using an Essence or Core?
@Guy Yes, seems so - I only noticed it recently. I haven’t had the chance to test it yet, but I am sure, that it will work. Erland/OneRemote knows what he is doing. MM
Yes, for many people that will be a better solution than an arc audio extractor followed by something to trigger powerlink.  I will try to remember to suggest as an option when answering forum questions.
I use - for an older Philips 32” tv in a guestroom - an ARC Extractor with an Essence MK2 (line-in) and a set of BL3. Works, but volume control is a bit fiddly. The tv volume has to be set high…..if I want it louder, I have to use  the Essence Remote (or the app). I assume, that it would have worked smoother with the Hall Audio Streamer or the OneRemote-box with the BL3’s directly connected. But I wanted the Essence (and Beolink multiroom) in the mix. That’ll do for now! If I could get my hands on a V1-32 at a reasonable price, I’d probably replace the current solution. MM
The ‘fixed sound level’ is not an option to me….. ….since I also want to use the sources of the Essence (in addition to the audio from the tv). MM
