EE TV Box Pro
Hello all. Will be leaving Sky soon, and looking at EE/BT's offerings as much cheaper. Does anyone know if the EE TV Box Pro can be used with B&O remotes? We have the Avant 55. Would normally just look it up in the PUC list, but I cant find a manufacturer for the EE Box. Thank you
Seems to be a Sagemcom branded box….if that helps you. MM
