Deregister faulty Beocom 2
Hi, Can anyone help? I have a beoline with 6 phones registered (3 beocom 6000 and 3 beocom 2). One beocom 2 is faulty with no working display. I have a replacement phone but I need to deregister the faulty phone first. I've no idea how to do this without a working display on the phone in question. Is it possible and if so how? Any help would be much appreciated. Thanks, Norman
Hi and welcome to Beoworld! On one of the working phones, go to ‘Settings’, then ‘Base’ then ‘Remove Handset’. Then scroll through to find the handset you with to remove and select.
Hi Guy, Thanks for your prompt response, welcome and solution. All is now well and having followed your instructions I'm feeling both pleased and suitably embarrassed by how simple a process it was. It's easy when you know! Thanks again. 🙂
