Datalink on Beogram Turntable
My question is if the Beogram 4004 would interact with an Beomaster 6000 ( not 4CH) or Beomaster 8000? Thanks for advice. Kind regards Christian
As far as I know it would work with both.  I have had a read of this and cannot see any limitations for either of those setups mentioned:
There are mentioning of some limitations in the datalink implementation in the Beomaster 6000 here
Not convinced it will work though will try it out when I can. The 4004 used a proto datalink and Tim on Beocentral suggests it is not compatible. I will let you know - will need to find where I put the spare DIN pins first!! The Beoworld piece also suggests that it will not work remotely. It will of course function perfectly well as a record player - I have used mine with all sorts of Beomasters.
The text on Beocentral i pretty clear that it will only work with a Beomaster 2400-2
It will not work. The "old" and "new" datalink systems are not compatible. Martin
I have made this :) https://forum.beoworld.org/forums/topic/beogram-4002-4004-upgrade/ It is making the BG4002/4004 act like a BG7000 with the modern Datalink beomasters. /Weebyx
Very clever! It amazes me how resourceful members are! I confess that I always clean the record before playing it as usually use a 20CL and any dust simply collects on the needle. And my best deck is completely manual. However clearly there will be demand though maybe a non RIAA version could also be popular.
