Creating custom PUC for unsupported devices
Hello, has anybody been able to create a custom PUC so that it works with 3rd party devices?
I'm half way there and I was able to control the Nvidia shield pro lately but there are keys that are mapped on the beoremote one that I don't understand what they do.
I have the IR codes of one the remote control I'm trying to integrate with my Beovision but the key association is a bit misleading. Any support is appreciated.
Login to view image
The numbers, cursor and back buttons are working however the Blue/green/red and yellow dots are not.
Red dot should be cont_red but it looks like it's not.... Also what's exactly Shift+1/2/3/4/5... on the beoremote?
Engineering since ever...
I’d appreciate any primer on how to build a custom PUC. I suspect if it can be done - and it seems you are doing it! That capability along with LIRC, should make it possible to control anything IR.
sounds very exciting!
