Connecting a Beocentre to a phone
I’ve purchased a Beocentre not sure which one(doesn’t have a tape player) and I’m trying to connect my son’s phone to it. Do I purchase a Beolink to female mic cable? I’ve got a Bluetooth receiver already. Any ideas as to what I need and where from?
Is your bluetooth receiver already connected to the ‘Beocentre’? If yes, how and which ‘button’ is used to activate the input? (Do you use a remote for the ‘Beocentre)? If yes, push that button and let him connect to that with his phone….he can find the receiver in the bluetooth settings there. Note: you/he will have to turn up the volume on the phone to almost max and then control the volume on the ‘Beocentre’. MM
What output connection does the Bluetooth receiver have?  If you can described that or post a photo (and one of the Beocenter!) we can suggest a suitable cable.
