Compatible Stands w/ LG C-series and Beosound Stage?
Hello! I have been looking at STBbracket's Focus Stand model [0] to use together with my LG OLED C-series and Beosound Stage. Ideally, I would like to have a motorised floor stand as I would need to, occasionally, move the setup. As such, I have been looking at the feasibility of retro-fitting or otherwise adapting original motorised floor stands, e.g. the BeoVision 7's stand. An alternative of course would be to position the Focus Stand on a material which, in a pinch, allows me to move the setup. Any chance someone here has experience doing the above, or maybe other ideas? Thanks! [0] https://www.stbbrackets.co.uk/product/focus-stand/
Hello, I’ve a 55” LG C-series and BeoSound Stage on my old BV11-40 motorised stand (using the STB converter). I have to say it works really well, obviously you can only move the stand manually but is allows for some flexibility whilst retaining that B&O look and feel, especially with the Beoremote One. Can’t comment on the focus stand, but it looks very similar, so might come down to whether you really need the ability to rotate…. Cheers, Matt
