BV11 on BV10 Stand--how to wire?
Looking for help with using a floor stand for a BV10 with my BV11 but the clips don't match. How do I wire these together? (I'm not sure I numbered them correctly according to standard convention, but BV11 #1 goes to which BV10 #, BV11 #2 goes to which BV10 #, which BV10 # is ground, et cetera?) Thanks! Gene
Normally I'd refer you to the service manuals (avail to Silver & Gold members), but here are screenshots from the relevant sections.  I am not convinced that it is straightforward but if you can get it to work please come back and let us know how! BV11: BV10:
I would no be to sure that these stands are compatible. 12V on one vs 14V on the other. Two wires with twoway communication on one vs 3 wires with one way communication on the other. You have to be very sure what you do if you try to combine these
Thank you!   I know to be careful which is why I asked!   Is the numbering in the schematic the same as my numbering? I know there must be a convention, but I don't know it.   Out of curiosity, is the Avant wired the same as a BV11?   Thanks again!
Thank you!   I think this is exactly what I needed:   https://iisb-foxbms.iisb.fraunhofer.de/foxbms/docs/latest/hardware/connectors.html
Bv10 stand are NOT electrical compatible with bv11 stand bv10 have turn left 5v and turn right 5v bv11 use CAN bus serial data
Thank you, Beouser 19! That is a big difference. I haven't tried anything yet and looks like I shouldn't. Is the stand from an Avant NG compatible with either BV10 or BV11?
