BV Avant 75NG satellite signal software problem
Dear All! My BV Avant 75NG shows strange behavior: it "looses" the satellite signal showing "no signal" (and of course black screen); if I do a hard reset (unplug) all the channels are back as if nothing happened; first I tried to redo the antenna but I think this behavior is due to a software issue which also might be  connected to missing updates (android/google). I was already thinking to reset the TV but than I get the even older software does anyone have an idea how this issue could be solved? My BV14 (should be the same software?) is running smoothly best regards Elmar
Dear All! I was thinking, that the CI Module made the problems - now my BV14 shows the same issue; but unfortunately I need to accept, that is looks like to be a failing internal B&O satellite receiver; now I am looking for a third party product which is "PUC-capable" and has a CI+ slot (i need CI+ module to watch ORF). please give some advice (no need of high end sat receivers). Thanks, marry Christmas and a Happy New Year Elmar
