Bs 9000 Minimum Softwarerelease to connect to NL/ml converter
Hello,   What is the minimum software version that the Bs 9000 (mk2) needs to have in order to run satisfactorily in a setup of bv11 + converter? I'm actually only interested in controlling the CD part, the rest runs via the bv11 anyway.   I would also be interested in how the software releases differ.   Greetings horst
Carolpa is the expert on this! Using a BLC is actually a great workaround for the BS9000 N.RADIO/N.MUSIC older software software problem. It will makes those sources individually accessable. See for example
