Beosound theatre feedback
Good morning,
I currently have a beocenter 9300 + beolab2+ beolab 8000.
I'm considering buying a Beosound theater to connect everything to my LG TV.
what is your feedback on the use of beosound theater (bug, use with the B&o app....)?
THANKS.
I've had theatres for 15 months now, one standalone and one as part of a surround setup.
On a standalone basis, the Theatre is mighty capable with respect to the sound image (height, depth and power) it produces.
It does seem a little more pointed / built for modern streaming than previous BVs - it can only control 2 peripheral devices using PUC (as opposed to 4), and sound wise it seems to sing with Atmos and Dolby Digital+ content, but less so with older codecs like PCM and Dolby Digital. As for integrating older B&O stuff into a Theatre setup, others will know better, but there seem to be issues / limitations here.
The current app also does not yet have a TV remote control function for the Theatre, in the way that exists for prior Beovisions - doesnt bother me, but does some.
The other thing to think about - depending on how particular one is - the Theater does require / invite a lot of tweaking, fiddling and setting up. True Image - their own up/down scaler - seems much less useful and relevant with the Theatre. Separate Listening Positions (replacement for speaker groups) need setting up and switching between for Atmos and non-Atmos content. On older BVs, you could rely on True Image to manage different signals best - whereas now, a user needs to actually switch between List.Positions.
Whether any of these foibles apply in your use case, I guess you will know better.
But when it comes to its capability when fed a good input signal, yes it does sound superb.
