Beosound moment limitations
Hi all,   I would like to open this thread in order to list all the beosound moment limitations, due to software no more updated.   I heard that the radio does not work anymore (because of TuneIn which is no longer supported) and also maybe deezer which also does not work properly. Is there any workaround (like using B&O radio instead of TuneIn)? Is there any other limitations ?   thanks
Im quite sure that artwork will not be updated for music files you have on e.g. a NAS, so artwork need to be added manually. Used to be picked from Gracenote if I recall correctly.
