Beosound Core / Beolab 50 volume control
Hello Beoworlders, My BL50s are connected to a Theatre through Powerlink and to a Beosound Core though Optical. In the Beo App and my Beoremote Halo, I cannot directly control the volume level of the Core. I have to choose what to listen and begin the playback in the BS Core page, then go to the BL50 page to control volume level. I suspect this could be corrected in the Core settings, but I cannot find where. And of course the B&O website is of no help as there is no user guide available but only a very limited FAQ where my question is not listed. Anybody can help? Thanks and kind regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Hi Beo APP -> Configure -> Sound -> OPTICAL-OUT - choose: “Volume regulated output”
Hi and thank you. Already done, but it does not work. BL 50s input is set to Automatic as I use several sources:
    <li style="list-style-type: none;">
    • Powerlink for the Beovision Theatre,
    • Coaxial for Wiim Pro Plus,
    • Optical for Beosound Core.
I wonder if the USB A on the Core is an USB audio output that I could connect to the 50s. Kind regards, Yann.
Are you finding a difference in sound quality between the Theatre and Core? Wondering the thought process for having both in the system
Being a Mozart product, the Theatre does not give a direct access to my ML sources (I do not find the "join" workaround very practical) . The Core does through the ML/NL converter. Yann.
Hi Is it a Beosound Core (old) or Beoconnect Core (new) you have? I have Beosound Core and Beolab 50, where I have the Core's optical output (line/optical combo 3.5mm jack) to the Beolab 50's optical input.
Hi, Could you post screenshots of the settings related to Optical in the app? As you I have a Beosound Core and the 50s are connected as follows: Optical to the Core Coaxial to a Wiim Pro+ Powerlink to Beovision Theatre Yann.
Hi, Attached is screenshots from SOUND -> OPTICAL and SOUND -> OPTICAL-OUT
Thanks. That's what I have but it does not work. I rebooted the Core several times without success. My 50s input selection is set to Automatic. Is it so in your setup? Regards, Yann.
Hi I have it set for Automatic with the following ranking of input. I have powerlink as 1st. (BL50 - Harmony) and 2nd. (BL50 - BS Core) - see screendump.
Attachments (1)
