Beoremote Halo
Hi dear Members
Is there anyone who can give me advice to get access to the battery of the Halo remote?
Could not find a service manual, or hints to open the remote from downside, where the battery lives.
Mine has gone bad because the battery last only a few hours.
Thanks for reply.
Kind regards
Christian
Under the rubber foot there are 4 screws, remove them and lift off the battery cover.
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
Hi
Thanks for that, I´ ll try next days.
Kind regards
Christian
Hi
Found the screws under the rubber ring, all ok.
Thanks again
Christian
