BeoMaster 5000 voltage conversion to 120v
Greetings, Looking for help:  Wanting to convert a 220v BeoMaster 5000 to 120v. I found the wiring schematic but it doesn't say what type thermal protection (maybe R40) nor how to mount it. Maybe someone has one or has done this? Also, curious if a fan might be better (saw a post about that). Thoughts? Thanks for your reply. Gene
R40 is the NTC resistor for the over-temp protection circuit in the amplifier section. It has nothing to do with the wiring of the mains transformer. The mains transformers shown on page 8-4 for 100V and 120V are different from the one used for 110/130/220/240V. Seeing as you have a Beomaster currently set for 220V: If you have 110V in your mains, I would convert to that. If you have 120V mains I would convert to 130V. If you absolutely must convert to 120V you must replace the transformer with a correct one (8013299, that has a thermal fuse built-in). You must also replace the mains fuse with one of twice the amp rating. (Half voltage - twice current - same power, also known as Ohms law). Martin
Many thanks, Martin! I have 110v but have seen it go to 115v which is why I was thinking 120v--probably too much thinking and not worth changing the transformer. Thanks for the reminder about the fuse! Regards, Gene
I wouldn't worry as long as we are within +/-10%. I don't think the power plants can guarantee a tighter tolerance anyways. Martin
Thanks again!
