beomaster 3500 glass panel broken
Ive caught the B&O bug. I bought a beomaster 3500 which I now have fully working.. apart from the bottom glass touch screen panel is broken ..  due to my leaving it in a bad place and a nosey cat. Does anyone have one or is there something from another machine that may fit? Dream audio vision no longer makes them unfortunately. I am also after a mmc4  or similar for the  beogram 3500, that's now working perfectly apart from the stylus that is worn out. How long does this addiction last ?
Maybe you could buy a non working BM3500 and use that as the donor for your Beomaster? The addiction is lifelong 😀
I feel you may be right about the addiction. Yes keeping my eyes open for a bm3500.
