BeoLiving Intelligence with multiple Philips Hue hubs
Does anyone know if the BLI works with multiple Philips Hue hubs? My home has thick concrete floors and interior walls which wireless signals can't seem to penetrate. I have to use multiple access points to get everything connected. Thanks in advance.
I never tried a second one because one seems to be sufficient in our house. But you can go to Systems and add a second driver to Global or a Zone/Area (I tried this and it is possible).
Then you should be able to add the settings and connections with this Hue bridge (same way as you did with the first one). Divide the lamps between the hubs and make Macros to set/stop room lights.
To be 100% sure send a mail to Khimo.
