Beoliving intelligence: Android App on Google Play Store is gone. What happened?
Hi, I wanted to install the Beoliving app for my Beoliving intelligence PRO on a new Android device but guess what: It's not available anymore in the Google Play store! On their website they still say the app is available for Android and iOS devices, phones and tablets: https://www.bang-olufsen.com/en/dk/accessories/beoliving-intelligence Is this a bad joke from B&O? I'm using the Beoliving app on a few devices and now wanted to install it on a new device. I'm using the Beoliving intelligence PRO device (the black one; looks different than the new white one). Does anybody know what happened?
Hello! There was an internal issue with Google Play preventing the installation of the BeoLiving app. That issue has now been resolved by Google, and you should be able to install it again: https://play.google.com/store/apps/details?id=com.khimo.beoliving Best regards, The Khimo team.
Hello Khimo team, thank you for getting back to me and that the issue is solved! Installed Beoliving on my new device and my blood pressure is down again to normal levels. ;-) Maybe it would be a good solution to add a direct download for the IOS and Android Apps on your website or the Bang & Olufsen website, too.
