BeoLink Wireless 1 - no audio with Masterlink connections only
Bought a BLW1 pair.  Used all known good cables and devices (from my main system), and the BLW1’s are paired to e.a. other (green lights) BS3000 <> Masterlink cable <> BLW1 Transmit BLW1 Receive <> Masterlink cable <> Beolab 2000 No sound.  Pressing “CD” on the BL2000 does not start the BS3000 CD, nor does “Radio”.   If I connect BS3000 <> Masterlink cable <> BL 2000, everything works as expected.   Bad BLW1s?  Return to seller?  Thanks in advance.
I think that the ML to ML function only works from a certain software version. In the first version you could only use the powerlink connection on the receiver like a Beolink Active, and need an IR eye
Looking in my notes i can see that it is from SW 2.1  from serial number 19956171 that the ML to ML functionality was introduced Source:
Problem with buying the W1’s used is that there is no way to tell the software version (except for the mentioned serial number), and units can have been upgraded with newer software without the seller remebering/knowing
Thank you Mads, great comments! The serial numbers are separated by a mere 30 units at the very top of the 20810900 range. Worth mentioning that both T and R go to sleep (solid red) after about 20 seconds, but pressing buttons such as “Play” or “CD” on the BL2000 immediately wakes up both the T and the R; … ergo, it appears ML traffic is sent, or at least an activity wake-up; however, the audio master BS3000 fails to wake up.  Also of note, having the CD already playing on BS3000 and then trying to get the BL2000 to merely JOIN has no effect. Sad!  Have to assume the BLWs are duds.
Exchanging the units, factory re-setting them, and re-syncing them: The BLW1 formerly ML’d to the Audio Master as T; now ML’d to the BL2000 as R:  The BL2000’s buttons fail to wake up this BLW1. Hypothesis: the ML circuitry on this BLW1 has failed, or its mechanical ML connection.  When the now R was the T, it was getting a wireless wake up signal from the other BLW1, and perhaps trying to wake up the Audiomaster, but it “found"  no detectable Masterlink. I wish I could test if the Powerlink (R) works from the (T) ML’d to the Audiomaster —which is all I really wanted out of this set-up—, but apparently this functionality is non-testable in the absence of a compatible IR Eye.  I have an IR Eye, but its termination is on an ethernet-like connector (RJ-45), not on a Powerlink connector (DIN). Sad!
I was just about to ssuggest something like that
  The BLW1 formerly ML’d to the Audio Master as T; now ML’d to the BL2000 as R:  The BL2000’s buttons fail to wake up this BLW1. Hypothesis: the ML circuitry on this BLW1 has failed, or its mechanical ML connection.  When the now R was the T, it was getting a wireless wake up signal from the other BLW1, and perhaps trying to wake up the Audiomaster, but it “found”  no detectable Masterlink.
That sounds like possible hypothesis.
The Round IR eyes with a DIN connector from a Beolink passive or active will work if you would happen to have any of theese in your system. Any B&O IR eye that receive signals from a Beolink 1000 or Beo4 will also work as long as just the ground, +5V and IR data is connected in the DIN connector. So if you happen to have and old MCL IR eye or something else lying arround and are able to solder it in a DIN connector it should be possible to do that.
One more thing. have you tried to control the Beolab 2000 with a remote instead of the buttons? It might be a long shot, but just in case something act's differently
I have a pair of bw1s that act like this.  LEDs behave normally, but, over the period of a year (iirc), they went from sporatic sound, then no sound. They mostly worked when new.
Hello Stan!  Yes, I must say, most B&O equipment tends to be solidly built, but sometimes misfortune happens! I wonder what’s B&O’s designed lifetime. Mads, I tried using the Beo4, again the (R) now connected to the BL2000 fails to wake up this BLW1 connected as an (R).  And unfortunately I have no other IR Eye.  So I’ve claimed a refund from the seller. Given the difficulty in ascertaining sw version, this could very well be the end of my explorations into the BLW1 world. Cheerio!
