Beolab connected to WISA and Powerlink
Hi everyone, Do you know if it is possible for a pair of beolab 18 connected to a beovision with WISA, to be also connected with a powerlink cable to a beocenter 2, or a turntable or any other device?   If yes, how is the experience?   thanks all
Connecting multiple sources to Beolab 18 at the same time is possible, but only when they are all wired. They are prioritised in this order:
  1. Power Link
  2. Optical input (Toslink)
  3. Line input (RCA)
It's not possible to use wireless and wired sources at the same time.
Human interface designer at Bang & Olufsen.
There is no way to use Beolab 18 as a "standalone" pair, it always needs to be connected to a source, wireless or wired. In wired use, the aforementioned prioritisation applies. Maybe you're thinking of Beolab 28 instead, which do have sources built in and behave differently otherwise too?
Hi,   thanks a lot for your answers I have a beovision 11, and I was thinking of buying a pair of beolab 18. my initial plan was to connect them with Wisa to the beovision, and also connect them to a beoconnect via powerlink, so that I can also listen to radio or spotify… But as you said, maybe beolab 28 would be a better fit for such use case.   thanks again
Related but different question. Can you have two Beolab 8's (1) stereo paired for music sources, and (2) WISA connected to a Beovision for TV sources? I don't want to wire anything. I think the answer is no, but maybe someone has been able to achieve this scenario.
I had the 8’s in wireless stereo pair and then connected via Wireless Powerlink to my Theatre. That worked absolutely fine. 28’s as well.
Thanks - I'm still having challenges but glad to know it's possible.
