Beolab 18's wall mounted speaker height
Hi Guys, Sold our house and we are moving soon, so need to setup the TV etc again, but our current setup as photo below, I lined up the top of the TV with the speakers etc. Question is: Do you think the speakers are too high, I mean it sounds good. But I cant find any info on the recommended wall height for the 28's. Does anyone else use them with the B&O Theater and if so what height are you running them and hows the sound?? Thanks TC
To my taste both the tv and the 18’s are too high up. But…remember, it is you that has to like the sound and the looks of the setup. Do I see a BL11 under the shelf? You might consider placing that in the back of the room for a more even bas reproduction in the new room. Happy experimenting MM
my BL18 are hanging about 15cm from the ground
Check this out
That's a great idea Millemis, moving the sub to the back of the room, I'll look into that when we move in. And thanks to DT79 for the link, good read! :)
