Beogram 7000 - sounds rough ?
Hi , new to the forum - I have a beogram 2000 with mmc4 plays vinyl well - paired with beomaster 5000 &beovox  c40  - also have beogram7000 mmc2 - needle has lost its touch - tried the mmc4 on the 7000 sound much improved but still not great ? Any ideas what else it could be  thanks  for any advice / help - NeilØ
Ø
That's pretty much normal. You've now joined the select club that has discovered first-hand that the last radial tracking Beograms sound much better than their linear tracking brothers. Don't tell everyone, though, otherwise the price of the radial trackers will shoot up! 😉
@Adams Interesting comment. How would you rate the BeoGram 4000 series, compared to other (later) linear tracking turntables, and radial tracking turntables?
The Beogram 4000/4002/4004/6000 models are completely different and are some of the best turntables B&O made, in my personal opinion. The same goes for the Beogram 8000/8002 models, although they are ruined somewhat by being largely held together with double-sided sticky tape. I really want to like the TX2/5005/5500/6500/7000 etc. linear tracking models - they look great, are lovely to use and they're easy to service (which isn't exactly a common thing for B&O...) but I've just always found them to sound quite disappointing. For what it's worth, it's an opinion that a certain Mr. Jarman also shares!
@Adams Thank you very much for sharing your experience. I haven't had the opportunity to compare all the BeoGram models, and experience their differences. So, this information is welcome!
A few things come to mind -- I'm sure you adjusted the tracking weight for the MMC4 when you put it on the 7000, but just wanted to check. Also, I recapped the RIAA pre-amp in my 6500 and noticed a great improvement in the sound...
