Beocenter 9500 controller PCB assembly
Hello All, My Beocenter 9500 buttons have stopped working, and supposedly it’s a faulty controller PCB assembly. Dose anyone know how to repair or where I could find a replacement? I have attached photos. any help would be greatly appreciated just want to save my beautiful Hi-Fi I’ve owned since the 90s Many thanks michael
Have you checked if the lower glass panel has come lose? If the glass comes away from its plastic holders, the conductive rubber bumpers will no longer have contact. It can also happen, if the glass was fastened using very thick tape. Martin
Hey mate Thank you for your reply Unfortunately it’s not the glass, because the buttons are still not working when you touch the rubber bumpers directly Regards Michael
Have you checked the backup battery? Martin
Hey mate i haven’t. when you keep your finger on the rubber bumper, they flash for a second michael
Hello   Can anyone tell me what this part is called? All I know it’s for a Beocenter 9500   Many Thanks michael
It's referred to in the Service Manual (available to Silver/Gold Members) as the System Control PCB, also known as PCB40 - it contains the main microprocessor (under the metal cover).  The attached battery is the backup battery (referred to earlier in the thread) that makes sure that the system retains its settings.
Many thanks much appreciated
